Activity Forums Apple Final Cut Pro Legacy How do you stop FCP from adding numbers when logging?
  • How do you stop FCP from adding numbers when logging?
    Posted by Dan Riley on August 13, 2005 at 12:08 am
    I can’t find it in the manual.
    This has bugged me for years.
    I don’t want FCP, when I stop a capture or the capture
    fails, to then change my 05 to an 06 or whatever
    in the description area of the logging window.
    How do you make it stop that?
    Dan
    Gary Adcock replied 21 years, 1 month ago 3 Members · 2 Replies
  • Jerry Hofmann
    August 13, 2005 at 1:29 am
    You can’t I’m afraid…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Gary Adcock
    August 13, 2005 at 2:10 pm
    [Danrnw] “I don’t want FCP, when I stop a capture or the capture
    fails, to then change my 05 to an 06 or whatever in the description area of the logging window.”
    You can use Letters instead…
    then you will not have those annoying numbers to deal with….
    gary adcock
    Studio37
    HD and Film Consultation
