Activity › Forums › VEGAS Pro › How do you speed up an ENTIRE video by 10%?
  • How do you speed up an ENTIRE video by 10%?
    Posted by Mike Bolson on November 8, 2008 at 3:36 am
    Hi everyone, I’m new to this and to Sony Vegas. I just finished an 18 minute video for a friend and as a test he wants the video as is (normal playback speed) and then the ENTIRE thing sped up by 10%.
    I see how you can do this to individual clips using envelopes but I have over 200 clips and don’t want to manually do this on each one, including audio.
    Is there an easy way to render the video and manually adjust it so the entire thing plays back at any given rate?
    Any help is appreciated!
    Mike
    Mike Bolson replied 17 years, 10 months ago 3 Members · 6 Replies
  • Theo Van laar
    November 8, 2008 at 12:33 pm
    You can (before rendering) import your .veg file as a nested veg into a new project and use the velocity envelop in the new project
    Theo
  • Mike Kujbida
    November 8, 2008 at 12:53 pm
    Drop a marker on the timeline so that you know where a 10% speed up should end.
    Do a Ctrl-A to select the entire timeline and then press the G key to group everything together.
    Place your cursor at the very end of the timeline (any event will do), hold down the Ctrl key (you’ll see a ~ show up under the box) and drag it backwards to the marker you made.
  • Mike Bolson
    November 9, 2008 at 2:24 am
    Wow thanks guys I appreciate the fast response! I will give both methods a try and let you know how it works.
    Thanks again!
    Mike
  • Mike Bolson
    November 10, 2008 at 8:15 pm
    Hi Theo, is just a standard import of file the same as a ‘nested’ import? I’ve been trying this and it’s just not working. If you can give me any more help that’d be great 🙂
  • Theo Van laar
    November 10, 2008 at 10:48 pm
    “Re: How do you speed up an ENTIRE video by 10%?
    by Mike Bolson on Nov 10, 2008 at 9:15:29 pm
    Hi Theo, is just a standard import of file the same as a ‘nested’ import? I’ve been trying this and it’s just not working. If you can give me any more help that’d be great :)”
    Just drag the .veg-file from the explorer (or even from Windows Explorer) to the timeline. Thats all. Your project will appear on the timeline as 1 video and 1 audio event.
    Theo
  • Mike Bolson
    November 12, 2008 at 12:45 am
    Thanks Theo – got it now!
    Mike
