Activity › Forums › Apple Final Cut Pro Legacy › How do you Slide a clip frame by frame using the keyboard?
  • How do you Slide a clip frame by frame using the keyboard?
    Posted by Uli Kunkel on January 12, 2007 at 4:36 pm
    When you select a clip in the timeline, you can type + or – (number of frames) and it will slide the clip left or right. But, what if I wanted to slide frame by frame until I reached the point that I wanted? Is that possible? It’s similar to holding down Command+ Left Arrow or Right Arrow in After Effects to move the playhead forward.
    Neil Sadwelkar replied 19 years, 8 months ago 5 Members · 4 Replies
  • Tom Wolsky
    January 12, 2007 at 5:28 pm
    Select the clip in the timeline. If there is nothing around it you can use the bracket [ ] or comma and period keys to move the clip. I it is adjacent to another clip you need to select the clip first then active the Slide tool (SS) then you the shortcuts to slide the clip.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Kevin Monahan
    January 12, 2007 at 5:40 pm
    Works also with slip as well.
    You can also trim a selected edit with the bracket keys.
    For all of these maneuvers, I do this on the fly while looping around the edit.
    Pre-Roll should be adjusted to be equal to post-roll and then you can get into a rhythm.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Chris Poisson
    January 12, 2007 at 7:50 pm
    The way I do this is hit the option key and the arrow key for 1 frame an add the shift key for 5 frames. Very handy.
  • Neil Sadwelkar
    January 13, 2007 at 3:02 am
    Option-right arrow to slide down, Option-left arrow to slide up, If something is in the way, Option-up arrow to take it to a higher track, and then option-right or left to slide it. If you’ve moved it to a higher track because something’s in the way, then you’ll need to trim out the start and end after silding.
    Neil
    FCP Editor, Mumbai, India.
    Completely PAL.
