Activity › Forums › Adobe Premiere Pro › How do you shorten over extended word in dialogue?
  • How do you shorten over extended word in dialogue?
    Posted by Olivier Prudhomme on November 10, 2017 at 12:00 am
    I am working on a documentary and the interviewee drags the end of some words like for ex:
    We went to theeeeeeeee beach
    She does that a lot and I need to shorten.
    Basic fading isn’t working well.
    Keyframing either…
    ANy idea / trick?
    Los Angeles – TV Promo Editor – FCP – AVID
    Olivier Prudhomme replied 8 years, 10 months ago 4 Members · 9 Replies
  • 9 Replies
  • Massimo Alberto croce
    November 10, 2017 at 6:44 pm
    You can try a fade with a short reverb and playing with dry\wet on the effect.
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
    November 10, 2017 at 6:46 pm
    The effect must be track effect not clip effect
    November 10, 2017 at 11:46 pm
    Or maybe cut in between the start and end of the eeeeeee so it can finish naturally
  • John Pale
    November 11, 2017 at 3:40 am
    If you send the clip to Audition, you can use its time stretch feature to play with this and see if you can improve it.
  • Andy Lewis
    November 12, 2017 at 3:19 pm
    Finding an example of a short “the” or “to the” from somewhere else in the interview and editing it in is probably easier than adjusting what’s there. With such a short sound you might even get away with using someone else’s voice.
  • John Pale
    November 12, 2017 at 7:03 pm
    “In other words, it ain’t easy to fix. Or fast.”
    Its not bad, really.
    Comparing the time wasted to find a similar sound and trying to cobble something together with less than satisfying results to using the right tool for the job.
  • Olivier Prudhomme
    November 13, 2017 at 12:52 am
    [Massimo Alberto Croce] “playing with dry\wet”
    not familiar with this… Is it the name of effect? Couldn’t find it.
  • Olivier Prudhomme
    November 13, 2017 at 12:54 am
    I’ll explore that
    thx
  • Olivier Prudhomme
    I tried but voice tone is too different
