Activity Forums Adobe After Effects How do you render out as an alpha layer? I cant work it out!?
  • How do you render out as an alpha layer? I cant work it out!?
    Posted by Daniel Haskett on May 19, 2005 at 10:54 pm
    hi there
    Basically I have an animation of a bird flying along, the bird is black and the rest is transparent. However when I go to make movie and choose Alpha Only, when I import the video in it has been inverted, the bird is now white and the transparent area black…? I just want the bird with no background at all…there must be a way?
    cheers!
    dan
    Daniel Haskett replied 21 years, 3 months ago 2 Members · 2 Replies
  • John Dickinson
    May 19, 2005 at 11:12 pm
    By rendering Alpha Only you are getting just that – an alpha channel with no fill (ie. the bird). In the Render Queue window look in the Video Output section and you’ll see a popup menu for “Channels” choose RGB + Alpha and that will do the trick!
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Daniel Haskett
    May 19, 2005 at 11:18 pm
    John Dickinson you are a star! Thank you so much 😉
    Dan
