Activity Forums Adobe After Effects How do you Render out an Avid Meridien Uncompressed codec?
  • Michael Hancock
    March 2, 2006 at 12:05 am
    720 x 486. Any size variation from this won’t allow you to render it. Otherwise, you can adjust the fields (lower field first recommended for Avid, rather than no fields), quality, resolution, etc. The only restriction I know is the actual comp size. Has to be 720 x 486.
    Mike.
  • Steve Roberts
    March 2, 2006 at 12:10 am
    … and if your levels run from 0 to 255 you might want to click the RGB (not YUV) buttom within the “options” for the codec in the Output Module. And tell the editor that you did that. 🙂
  • Milton Hockman
    March 2, 2006 at 4:41 pm
    can you explain the yuv vs. rgb thing?
  • Milton Hockman
    March 2, 2006 at 4:42 pm
    what if i create a 960×540 comp to do widescreen. How do i use the Uncompressed codec then?
