Activity Forums Adobe Audition How do you remove volume level info brought in via OMF aka How do you adjust volume of multiple clips back to default?
  • How do you remove volume level info brought in via OMF aka How do you adjust volume of multiple clips back to default?
    Posted by Scott Clements on April 9, 2013 at 1:22 pm
    I can’t seem how to figure out how to remove the levels adjusts I made in FCP and wrongly brought into Audition via OMF. I can’t seem to figure out a way to select all the clips in the Audition timeline and reset the envelopes? back to their default. So, I have all these horizontal yellow lines going across the clips at various heights, but can’t get them back to zero without going through and adjusting each one manually. Does anyone know how to get around this? Thanks.
    Film Editor, London UK
    http://www.scottclementseditor.com
    Scott Clements replied 7 years, 9 months ago 3 Members · 5 Replies
  • Steve Murray
    August 21, 2013 at 10:45 am
    Hi Scott,
    Did you ever solve this? Struggling with exactly the same thing today…
    Cheers,
    Steve Murray
    Synergy Films
    Auckland, New Zealand
  • Scott Clements
    August 21, 2013 at 12:35 pm
    Hi, Steve.
    No, I didn’t solve this the way I wanted to. I just exported OMFs from the NLE and chose to eliminate level changes on OMF export.
  • Steve Murray
    August 22, 2013 at 10:25 am
    Thanks Scott.
    Yes, that was going to be my fall back as well… Seems an oversight though!
    Cheers,
    Steve Murray
    Synergy Films
  • Desi Ortiz
    November 26, 2018 at 11:49 pm
    Any solution for this? (5 years later?)
  • Scott Clements
    November 27, 2018 at 1:55 am
    Sorry. I don’t really use Audition anymore.
