Activity › Forums › Adobe Premiere Pro › How do you remove normalisation gain?
Posted by Scott Clements on February 24, 2015 at 1:20 amHi, I asked about this in the basics sections, but got no satisfactory response. How do you remove normalisation gain if you change your mind and don’t want it?
Film Editor, London UK
http://www.scottclementseditor.comScott Clements replied 11 years, 7 months ago 3 Members · 5 Replies -
Tero Ahlfors
February 24, 2015 at 7:00 amI tested this out and if you’re using the normalize master gain-command then it just touches the level of the master track. So go into the audio track mixer and bring the master track back to zero.
Scott Clements
February 24, 2015 at 10:29 amNormalisation is applied on a clip by clip basis. If you apply normalisation to 2 clips…one with a person speaking and one that is just room tone, the room tone will be ludicrously loud. Once it is applied to the room tone, I don’t know how to remove it. In FCP 7, you just delete a gain filter – not the case in Premiere. So, it is not a case of just adjusting the level of the master track.
http://www.scottclementseditor.com -
Nils Welter
February 24, 2015 at 9:57 pmSelect all affected clips in timeline. Hit G for audio gain, then set gain to 0 (first row). Setting absolute gain to 0 means reset to default.
Nils Welter
Adobe Certified Instructor – Premiere ProCBC Cologne Broadcasting Center
Cologne, Germany -
Scott Clements
February 24, 2015 at 10:00 pm
