Activity Forums Adobe Audition How do you remove Heart Beat from speech wav
  • How do you remove Heart Beat from speech wav
    Posted by Clif Willard on May 5, 2005 at 3:12 am
    Hi All,
    I have a tape that was recorded with a lavelere mic. The mic was clipped to the man’s shirt so you can hear his heart beat throughout his speech. How can I remove the heart beat? I tried the equalizers and noise reduction but no luck. Any suggestions?
    Audition 1.5
    Clif
    Clif Willard
    NON ILLIGITIMI CARBORDUM
    Clif Willard replied 21 years, 3 months ago 3 Members · 3 Replies
  • Steven L. gotz
    May 5, 2005 at 4:55 am
    Clif,
    I believe the phrase is Non Illegitimi Carborundum
    Getting rid of the heartbeat might be a good use of the Spectral View that Willie has mentioned a few times lately.
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Willie Toth
    May 5, 2005 at 11:05 am
    Clif,
    One thing to watch for, if you are getting a heart beat your gain much have really been up, or it was a combination of gain and placement … It will be a lot of work to remove it because you have to do each beat individually, but I think the only way is using the spectral view … The problem we run across is that the voice might be degraded by using the spectral view … Let us know the outcome … It might be easier if you could shoot it over …
    Willie
  • Clif Willard
    May 9, 2005 at 3:34 am
    Oops, thanks for the correction. I am trying Spectral view. I will let you know.
    Clif
    Clif Willard
    NON ILLIGITIMI CARBORUNDUM
