Activity › Forums › Apple Final Cut Pro Legacy › How do you remove frame blending forever!? For slo mo
  • How do you remove frame blending forever!? For slo mo
    Posted by Justin Ferar on April 13, 2006 at 6:53 pm
    I do a lot of slo motion montages. The best way is to get the settings right on one clip and then paste settings to the rest. Even though I have removed frame blending it still pastes it on to the rest of the clips. Then I have to command J through thirty clips and uncheck each and every one of the little bastards!
    Any work arounds for this BUG?
    I have already scoured the freakin manual to pieces on this.
    Justin Ferar replied 20 years, 5 months ago 2 Members · 2 Replies
  • Mark Maness
    April 13, 2006 at 7:30 pm
    Did you check your render settings? Look under the Sequence settings and look at your render settings… Is it set to norrmal? If so, set it to Best.
    _______________________________
    Wayne Carey
    Schazam Productions
  • Justin Ferar
    April 14, 2006 at 6:06 pm
    Hi Wayne- I’m not reffering to the quality of the render. If you Command-J a selected clip you will see a “blend frames” checkbox.
    What I want is to have the default unchecked at all times.
