Activity Forums Avid Media Composer How do you relink on the Avid?
  • How do you relink on the Avid?
    Posted by Hairy Michael on August 30, 2005 at 7:13 pm
    Hi again,
    I’m onlining a 2 hour documentary that has over 120 effects (pans across photos and newspapers, etc.) that were originally brought in wrong and looked terrible. I have since brought all of these effects in correctly and deleted all of the old ones.
    I do not know how to relink the now offline clips to the bins where I put all of the good effects. I tried selecting the sequence and using the Relink option in the Clip Menu, but that did not work.
    I also have a few of the original, horrible-looking effects that for some reson did not go offline when I deleted those media bins. Any ideas what to do about that? Avid’s help menu is not very instructive here.
    Thanks in advance! [Avid Media Composer 10.6]
    MJA
    Did I leave the iron on……?
    Dominic Gallagher replied 15 years, 9 months ago 4 Members · 4 Replies
  • Todd Beabout
    August 30, 2005 at 8:51 pm
    It’s not going to do the same function that you are used to in FCP with the “Reconnect offline media”, but you do have some options. I would suggest selecting the sequence that you want to relink, then select “Batch Import” from the Clip menu (I think). You should then get a list of media and the source file for each clip (this will only work for clips that were imported… not digitized, but I think that is your situation based on your last post…). Some of the clips will be red if you actually deleted the original, wrongly-imported ones and by clicking on each clip you can point it to where the new clip is. After you point each file to the “new” one you should be in business.
    Good luck!
    -Todd Beabout
    Vazda Studios
  • Hairy Michael
    August 30, 2005 at 10:52 pm
    Todd,
    First, thanks for responding. The batch import option will only look for files outside of the Avid (folders onthe network and “my computer” etc). I have already imported these quicktimes into the project. Batch import will take the QT I point it to, and then take about 3 minutes to create a new piece of video from that QT.
    !!!!!!! Just figured it out !!!!!!!
    1] Locked the bins with my new, working QTs.
    2] Decomposed my sequence and deleted all teh media (not master clips) to the old, bad QTs.
    3] In Decomp bin, chose “tape” heading.
    4] Click on tape name of BadQT.mov, Ctrl+C
    5] Highlight corresponding GOOD QT, modify, set source
    6] Selct “new tape”, Ctrl+V (had to do this because Avid would not let me type in the puntuation in “.mov”)
    7] Temporarily move GOOD QT into same bin as sequence.
    8] Highlight both, right click, Relink
    9] Repeat 143 times.
    And knowing…
    …is half the battle.
    MJA
  • Kevin Downer
    September 1, 2005 at 5:22 am
    For future reference, there are a few pointers that might help.
    As you found out, it is best to batch import the online material after you have finished editing with the offline material and do not need it anymore. It helps reduce the clutter. In newer verions of AVID, I think it is standard across the board to be able to relink to a select online resolution though which may help keep it all separated.
    I think you may have had offline bad media still online because you either imported them into a separate bin, or possibly in multiple projects project. I find it is always a good idea to try to create a separate project just for graphics, and another for music etc. This helps you keep things organised later on when you are trying to delete material int the Media Tool. You can always use Media Tool and Select Media Relatives to fins out what material your sequence uses and and be selective in your media control.
    You don’t have to copy paste ad nauseum in AVID for tape ID. You can create a tape for one item (whether it be graphics, music, etc.). Then highlight all the clips you want to change and use the Modify Clip command and set source, then seelcting your proper TAPE ID. This would have saved you the 142 keystrokes. The inability to use puncuation is so it won’t screw up EDL’s and it best to avoid lengthy or punctuated TAPE ID’s anyway.
    For graphics, three things to remember if you are doing rough offlines and then online finals is it helps to keep the exact names of each set intact and the same (even if they originate from different folders on your computer, import them with the same duration and give them a pseudo Tape ID like “GRFX001”. If you do this, you can then organise the offline graphics, delete the rough stuff (media only) and then use the [i]Relink Command[/i] which will look for the same tape, duration. etc. and relink your previous offline material clips to the proper online grfx media all in one go.
  • Dominic Gallagher
    December 18, 2010 at 9:18 pm
    There has to be a simpler way to do this? Something that takes a matter of minutes on FCP is going to take days or weeks using the methods outlined above? Don’t avid realise tapes are on the way out…
