Activity › Forums › Adobe Premiere Pro › How do you recapture clips
  • How do you recapture clips
    Posted by John Baum on October 11, 2005 at 4:58 pm
    Is there a way to recapture clips already in the project bins?
    In Vegas you just right click and choose “recapture”. Looking for something similar if it exists.
    John Baum replied 20 years, 11 months ago 4 Members · 11 Replies
  • 11 Replies
  • Craig Howard
    October 11, 2005 at 7:38 pm
    Create and export a batch list. Use this file to recapture clips.
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Aanarav Sareen
    October 11, 2005 at 10:41 pm
    Locate your clip in the project window > right click > Batch Capture > Insert the tape into your device and Press capture 🙂
    Aanarav Sareen
    Adobe Certfied Expert, Premiere Pro
    https://www.asvideoproductions.com/video
  • Craig Howard
    October 11, 2005 at 10:50 pm
    That option will be greyed out I believe.
    So select clips in Project window >Project Menu > Export Batch List etc….
    Craig
    Auckland
    New Zealand
  • Aanarav Sareen
    October 11, 2005 at 11:35 pm
    [Craig Howard] “That option will be greyed out I believe.”
    It will only be greyed out IF the clip is linked to a media file. If it is not linked to a media file, then the options will not be greyed out.
    Screenshot here
    Aanarav Sareen
  • Craig Howard
    October 12, 2005 at 6:07 am
    Not sure I understand Anarav
    The poster wanted to recapture clips already in the bins ( for some reason).
    If you select a clip in the bin by right clicking on it, you can not recapture it by batch process in the manner you suggested.
    Well I certainly can not on my setup because it is greyed out and I have always exported a Batch list for this purpose.
    We may be talking at cross purposes ?
  • Aanarav Sareen
    October 12, 2005 at 6:22 am
    I meant that if the clip is UNLINKED then the option will become activated not otherwise. Basically, we both are right. 😀 Just using different scenarios.
    Aanarav Sareen
  • John Baum
    October 12, 2005 at 5:04 pm
    I wanted to recapture some clips that had bad audio levels.
    So, if there not used in the timeline I can do this? Or do they have to be unlinked.
    What does link unlink mean anyway?
  • Craig Howard
    October 12, 2005 at 10:32 pm
    Recapturing them may not help the audio problem if you captured from a dv source ( stream)
    Craig
    Auckland
    New Zealand
  • John Baum
    October 13, 2005 at 8:03 pm
    Don’t worry, it will help.
    I just installed a patchbay for my audio and didn’t realise I had the audio I was trying to capture routed wrong.
  • Larry Sherwood
    October 13, 2005 at 11:14 pm
    Rt. click on one of the bad clips in the bin
    Choose Unlink Media
    A window will open and ask if you want to keep the media or if you want to delete it. Since the audio is bad I would assume you would Delete the file.
    Confirm the Deletion
    Rt. click the clip again and choose Batch Capture
    That should do it.
    Hope this helps
    LS
    Larry Sherwood
    Sherwood Post Production
    Austin, Texas
    512 219-8721
    larry@sherwoodpost.com
