Activity › Forums › Adobe Premiere Pro › How do you paste an effect to multiple clips in a bin at once?
Posted by Scott Clements on May 1, 2015 at 12:54 pmHi, I’m trying to apply a lumetri look to multiple clips in a bin at once. Is this possible? “Paste attributes” is greyed out.
Film Editor, London UK
http://www.scottclementseditor.comKris Strobeck replied 2 years, 9 months ago 5 Members · 5 Replies -
Tero Ahlfors
May 1, 2015 at 1:09 pmPaste attributes only works on the timeline. You might want to look at using a master clip effect or an adjustment layer.
https://helpx.adobe.com/premiere-pro/how-to/apply-effects-master-clips.html
Scott Clements
May 1, 2015 at 2:43 pmThanks. I was adding master clip effects, but can’t figure out how to add a LUT to every shot in the bin all at once -I don’t want to open each one – one by one. I find adjust layers across the whole timeline to be a bit messy while editing.
http://www.scottclementseditor.com -
Craig Howard
May 3, 2015 at 3:24 amSelect all the clips in the BIN that you wish to have any kind of Master Clip effect applied to. eg a LUT.
You can do it one by one to any Source Clip in the Source Monitor as well.
Craig Howard
Shooter Film Company
Auckland
New ZealandAdobe CS6 Premiere Pro Production Premium Suite
Windows 7-64 bit:Assus P6T Deluxe Mob, 24 GB BM SDI Decklink, . HD Workflows -
Colton Davie
September 16, 2015 at 9:21 pmHere’s how to apply a LUT to multiple clips at once:
– Add the Lumetri effect to one of the clips in your project tab and choose the LUT you want to use.
– Right click the Lumetri effect in your Effect Controls tab and “Save Preset…”
– In the Project tab, select all the clips to which you want to apply the LUT.
– Drag your saved preset from the Presets folder of your Effects tab onto one of the selected clips in you Project tab.
All of the selected clips should now have the LUT applied.
Took me a bit of searching and messing around to figure out this pretty obvious solution. I hope it helps!
Colton Davie
Cinematographer
https://coltondavie.com -
Kris Strobeck
November 30, 2023 at 8:28 pmNeeded this today and just now seeing it and it did exactly what you said. Thanks!
