Activity Forums Apple Final Cut Pro how do you move several connected clips AT ONCE?
  • how do you move several connected clips AT ONCE?
    Posted by Michael Paul on October 6, 2016 at 2:52 pm
    So here is the scenario: I have 3 connected clips that connect to one long clip. All 3 connected clips are secondary story lines. They are all text objects with a fade in and fade out. Now I want to do something VERY simple. MOVE THEM. I select all 3 STORYLINES by shift clicking on the story line so that the story line box (or whatever its called) gets a yellow outline – yes I make sure that the story line is selected and not just the text clip inside that story line. After I’ve selected all 3 story lines that contain text I want to move them so that they play a bit earlier on my main clip but no matter what tool I use Select (A) or Position (P) I can only move ONE story line at a time (they are exactly arranged/timed all together which gets totally destroyed when I move them seperatly).
    So is it impossible to actually MOVE stuff around in FCPX or is the solution once again: Just nest them and create a compound clip. This seems like a workaround for something so simply- so fundamental- something that is just moving clips in a NLE.
    THANKS A LOT!
    Michael Paul replied 9 years, 11 months ago 2 Members · 2 Replies
  • William Davis
    October 6, 2016 at 3:07 pm
    It seems to work normally here.
    1) Command click multiple storylines.
    2) Select one without holding Command.
    3) Move as needed.
    Maybe you’re command-clicking on one after you’ve selected?
  • Michael Paul
    October 6, 2016 at 3:27 pm
    I did NOT command click. I shift clicked. THANKS A MILLION. This was driving me nuts.
