Activity Forums Blackmagic Design How do you monitor S/PDIF audio outputs from Decklink
  • How do you monitor S/PDIF audio outputs from Decklink
    Posted by George Evatt on July 4, 2006 at 12:06 pm
    I just got a Decklink Pro card for my PC and need to output an Adobe premiere Pro 2.0 Project to Digibetacam.
    Everything went well installing it, it all plays out to my monitor, no worries. But the audio outs from the Decklink card are something called S/PDIF which is a digital audio protocol I think? How do I monitor the audio using these outputs?
    Can I buy speakers that I can plug the RCA S/PDIF plugs into or do I have to get a new digital amplifier and speakers?
    I.e. Any suggestions for a cheap way to monitor the S/PDIF outputs?
    I don’t own a digibetacam deck so cannot montor via the SDI output.
    Any info much appreciated.
    George
    Sean Lander replied 20 years, 2 months ago 11 Members · 12 Replies
  • 12 Replies
  • Bob Zelin
    July 4, 2006 at 1:12 pm
    SPDIF (Sony Phillips Digital Interface Protocol – I think) is an industry standard digital audio protocol. There are many companies that offer SPDIF monitoring. One of the original solutions from Blackmagic was to use the Edirol speakers (under $200) that offer a SPDIF input. If you just want to buy a monitoring converter, M-Audio (used to be Midiman) makes several boxes between $200 – $300 (like the Flying Cow) that will convert SPDIF to analog audio, so you can plug right into your analog amplifier.
    If you say “but I want to spend less than 50 bucks – how can I do this” – I have only one word for you – EBAY.
    Bob Zelin
  • Kristian Lam
    July 4, 2006 at 11:35 pm
    Hi George,
    Another lower cost option will be the Behringer ULTRAMATCH PRO Sample Rate and Format Converter. It’s a rack mount unit.
    regards
    Kristian Lam
    Blackmagic Design
  • Alejandro Maldonado
    July 5, 2006 at 4:10 am
    Would AES/EBU (on a Decklink HD Extreme) be the same as S/PDIF? I have a Sony amplifier that has S/PDIF but googling I found that AES/EBU and S/PDIF even when they are similar aren
  • Francisco Rubiales
    July 5, 2006 at 4:33 am
  • George Evatt
    July 5, 2006 at 5:06 am
    Thanks for all the suggestions. I ended up buying some Edirol MA-10 amp/speakers. They are very styish and except analogue and digital inputs. They cost $275 Australian Dollars.
    Regards
    George
  • Mel Matsuoka
    July 5, 2006 at 5:23 am
    I second the recommendation for the Extigy.
    If you have simple monitoring needs, it’s the perfect, most inexpensive solution I could find. I bought 3 of them on eBay for around $150 total.
  • Aaron Neitz
    July 5, 2006 at 6:28 pm
    From what I understand, SPDIF is basically an unbalanced AES signal. So if you have something to turn that RCA into an XLR or BNC, you can typically connect it to an AES plug and it works.
  • Kristian Lam
    July 5, 2006 at 11:38 pm
    Hi Charlie,
    Unbalanced AES or SPDIF is 75 ohms. You must convert the connection with a impedance converter as balanced AES is 110 ohms.
    regards
    Kristian Lam
    Blackmagic Design
  • Trevor Kinsey
    July 10, 2006 at 6:47 am
    For anybody else out there still looking for a solution; we have one system using a Flying Cow, but on the other we simply split the XLR outputs with Y cables. Of course you need a monitoring system that handles balanced audio, in our case an input on the mixer that controls the input, with its output set to only go to an auxilliary output which feeds some powered monitor speakers.
    Trevor Kinsey,
    Technical Producer,
    CVP Film and Television,
    Melbourne,
    Australia
  • Felix Dames
    July 10, 2006 at 12:47 pm
    you shopuld have bought the speakers Behringer MS-40 they are much cheeper (129
