How do you make a video with a transparent background?
Mike Kujbida replied 14 years, 2 months ago 10 Members · 21 Replies
Holly O’neil
May 29, 2008 at 1:46 pmWell, we had success this way. Open the video from the chroma keyer movie icon on the video. It is the little icon on the bottom right. It opens up all kinds of options. It’s the Video Event FX button. Then select the Chroma Keyer option. Then use the eydropper tool to take away green (or whatever color) background. You can even do this on the preview screen. Then to adjust the thresholds appropriately go ahead and place some video underneath the chroma key video to move thresholds till you get the best look. Then go ahead and delete that video. Then render as: Video for Windows AVI, use default template- uncompressed, then choose custom setting and then choose video rendering quallity best, then select the Video settings button and set at 720×480, field order none (progressive scan) and make sure render alpha channel (uncompressed window formats only) and create an OpenDML are checked. Then render. Voila! Thanks Douglas Spotted Eagle, Holly O’Neil
Jim Bannon
December 7, 2011 at 8:41 amThis topic is so well covered here for Sony users, I hesitate to ask if anyone can refer me to a solution using Cyberlink’s Power Director 9. (I have searched and posted in their forum)
I was led to this forum and appreciate the excellent dialog.
Thanx in advance for any “General Assistance” that might help.
Elsie Morgan
June 17, 2012 at 11:25 pmHi,
I tried everything you showed here but when I use dropper, i get rid of color leaving me a black background.
I appeared to ahve followed the rest of your directions but
when I rendered it and tried it in my website, it came up with the black background not a transparent one.Any ideas?
Thanks.
EHM
Elsie Morgan
June 17, 2012 at 11:29 pmHi,
Replied to wrong link. Wanted it to go to you.I tried everything you showed here but when I use dropper, i get rid of color leaving me a black background.
Thanks.
EHM
Elsie Morgan
June 18, 2012 at 12:59 amYes, I rendered it as uncompressed avi.
when you remove the background, should it just show black in the view screen?It ends up rendering as the same black background as when I removed the color.
Mike Kujbida
June 18, 2012 at 1:00 amPlace something under it to make sure that it is indeed transparent.
Elsie Morgan
June 18, 2012 at 1:08 amIt does not seem to become transparent.
I put a screen behind it and it does not show through when I remoe the color.
Suggestions?Thank you for your help.
Mike Kujbida
June 18, 2012 at 1:13 amIf you can, pleas post a high res screen shot from your preview window (set it to Best/Full and save as PNG) so that we can experiment and see where you’re going wrong.
