Activity › Forums › Canon Cameras › How do you like your XH-A1?
Posted by Jln2112 on January 22, 2007 at 11:01 pmI would be interested to hear some feedback from those of you that have been using the XH-A1. Any general impressions (likes/dislikes) thus far?
James Hooey replied 19 years, 6 months ago 6 Members · 10 Replies -
S2videos
January 22, 2007 at 11:14 pmI am also a day or two away from ordering one…. your thoughts and impressions would be great!
Prolog
January 26, 2007 at 11:06 pmI’ve been shooting for 20 years, and this is the most intelligent camera I’ve ever had. It has every adjustment I ever wanted. It almost guarantees excellent footage, if you set it up right (which is easy!!).
Phillip In montana
January 27, 2007 at 2:05 amCan you shoot and edit SD video with this camera? Do you have to down convert from HDV to SD? Where did you purchase, what comes with the package for the price and how much. I really like the specs on the camera and will probably purchase one. I’m just not set up for HDV and don’r want to go that routs just yet. Thanks
Phil in Montana
Prolog
January 30, 2007 at 1:54 pmCan you shoot and edit SD video with this camera?
YES, A SIMPLE MENU SWITCH AND STANDARD DV OUT GETS YOUTHEREDo you have to down convert from HDV to SD?
NO
CHECK WITH ALL DEALERS- I RECOMMEND FULL COMPASS– THEY KNOW THE GEAR AND STAND BEHIND YOU; THEY MAY BE A FEW BUCKS MORE, BUT DEFINITELY WORTH IT– THEY LOVE TALKING TO THEIR CUSTOMERS AND IF THEY DON’T KNOW THE ANSWER, THEY’LL CALL THE FACTORY TO GET IT.I really like the specs on the camera and will probably purchase one. I’m just not set up for HDV and don’r want to go that routs just yet. Thanks
IF YOU CAN AFFORD IT, GO HDV; BUT IF YOU PLAN TO GET A NEW CAMERA WITHIN 3 YEARS; GET STANDARD DEF AND SAVE SOME $$ HDV IS REALLY A CHEAP ENTRY INTO BROADCAST TV. FOR WEDDINGS, INDUSTRIAL, YOUTUBE, SD IS FINE UNTIL THERE’S AN AFFORDABLE HD DISTRIBUTION MEDIUM.
Phillip In montana
January 31, 2007 at 12:31 amI really appreciate your comments. Thanks a lot!
Phil in Montana
Lou Bruno
February 3, 2007 at 12:40 amThe camera shoots in SD, SD Widescreen and HDV. Just adjust the menu. You can downconvert via the camera menu. Best HDV camera of the three I owned.
Lou Bruno
Phillip In montana
February 3, 2007 at 1:44 amThank you Lou. I am going to purchase this camera next week.
Phil in Montana
Phillip In montana
February 4, 2007 at 5:43 pmI suppose I will purchase it from B&H. But I’ll look at several other outlets and let you know. B&H lists their package (without case) for 3666.00 and they have a decent reputation for quality service.
Phil in Montana
James Hooey
February 18, 2007 at 8:31 pmgreat camera!!! I only have one dissapointment with it…the zoom, focus and iris rings are servo control mechanisms and as such they have a rather limiting shortcoming…. you cannot zoom and adjust focus at the same time. Typically not a problem but there is the occasion from time to time where focus will be lost while zooming from close subjects to distant ones. Manual control rings would solve this I believe but then that’s more $$$ and it also requires a pretty good operator.
On the plus side though…excellent video quality, good compliment of manual controls and the size is unobtrusive. Basically it rocks.
