Activity › Forums › Apple Final Cut Pro › How do you handle audio ticks due to rough edit boundaries?
Posted by Ty Ford on August 4, 2015 at 2:29 amHi,
Most audio programs, like Pro Tools for example, have a crossfade tool that allows you to eliminate ticks. I haven’t been able to find one just for audio in FCP X. Is there one?
Or do I click on the clip, drop the audio timeline down and try sliding?
Ty Ford
Cow Audio Forum LeaderWant better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Ty Ford Blog: Ty Ford’s BlogMark Smith replied 11 years, 1 month ago 6 Members · 11 Replies -
Noah Kadner
August 4, 2015 at 3:01 amHey Ty-
FCPX audio containers have fade handles at the edges. You can also keyframe audio in the inspector or on a clip. That said- ticks I’m assuming you mean audible pops shouldn’t happen if the sampling rates are in order. Perhaps you could describe the situation in more depth?
Noah
FCPWORKS – FCPX Workflow
Call Box Training -
Jeff Kirkland
August 4, 2015 at 3:46 amI use the fade handles for a quick fix otherwise I use CTRL-S to reveal the audio, zoom in as much as needed and massage the edit a little. Usually only takes a few seconds to sort out.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland -
Ty Ford
August 4, 2015 at 7:21 amHi Noah,
They are zero crossover errors from two dissimilar sections of audio bumping up against each other. I tried the Control S suggestion. That worked in one situation but caused 2 clicks in the other.
Regards,
Ty
Ty Ford Blog: Ty Ford’s Blog -
John Fishback
August 4, 2015 at 6:51 pmIt’s amazing zero-crossing edits aren’t standard. In the 90s when we used a Sonic Solutions DAW every edit was made at a zero point. You get clicks because you have a step-function where one side of the edit is low energy and the other is higher. The sudden transition manifests as a click. What I do to eliminate this kind of click is extend the audio on both sides of the edit and apply fades to each. It’s a bit of a pain, but that will eliminate zero crossing clicks.
Then there’s Alex4Ds Sound Only transition here.
Noah Kadner
August 4, 2015 at 7:02 pmHmm I’d take a good at the sources- haven’t hit this in years of FCPX editing. Or maybe you could provide an audible example for those of us not quite so attuned as you are.
Noah
Call Box Training -
John Fishback
August 4, 2015 at 7:35 pmWhere I notice it happening a lot in dialog is where one take has a strong low frequency rumble (which in most cases you’d never hear without a sub woof) and it cuts to a take where the rumble is gone. If no SFX or music is there to mask it, you’ll hear a click. You can see the low freq rumble on meters. Another way to lessen this kind of click is apply a hi-pass filter that takes out the very low frequencies.
Jeff Kirkland
August 4, 2015 at 8:59 pmAt the end of the day audio editing isn’t FCPX’s strong suit. Sometimes there’s good reason to send the audio to an external app for finishing.
But I can say that I’ve been exclusively editing in FCPX since the day it was released and I could count on one hand the times I had a zero crossing issue, and I can’t remember any time I couldn’t massage it away by tweaking the edit at the sub-frame level.
Ty Ford
August 4, 2015 at 9:05 pmHello John,
Yes, I know about Zero Crossover errors. I was just expecting a less kludgey fix.
I got rid of them, but sheeseh!
Good to see you out here.
Regards,
Ty
Ty Ford
August 4, 2015 at 10:09 pmJeff,
Thanks, how do you zoom to the sample level without getting bloody nose?
Will the zoom bar take you that close?
Ty
Iman Rastegari
August 5, 2015 at 9:10 pmI usually use Cmd-= and Cmd– to quickly zoom in and out; you can zoom in super close and trim/adjust the audio levels easily, then zoom back out and continue with your edit. The audio fade handles are super handy, and you can also keyframe if needed by Opt-clicking on the volume line in the clip.
