Activity Forums Adobe Premiere Pro How do you get your windows back again…brain melt
  • How do you get your windows back again…brain melt
    Posted by Jason on October 29, 2007 at 9:25 pm
    Hey guys,
    I know there is a way to do this but my brain is melting and just can’t remember. I’ve opened up Media Encoder in PPRO CS3 and the top of it goes beyond the top of the monitor and I can’t drag it back down…hmmmm…..how the heck did i used to fix that? Any help appreciated.
    Running MAC CS3
    Cheers
    Jason replied 18 years, 11 months ago 2 Members · 2 Replies
  • Scot Sheely
    October 29, 2007 at 10:25 pm
    I would suggest, as a simpler measure of fixing this issue, to re-size your desktop in your display options.
    Just choose a LARGER size than you are using now (like 1920×1440 or 1600×1200 if your VGA will allow for those screen resolutions).
    Then you will be able to see the top of the Media Encoder and drag it down. When you close that window and re-open it again next time, it should remember the window position.
    You can then re-set your display to your original configuration at that point.
    I am sure there is another way to accomplish this feat, but I don’t recollect another method at this time.
    Scot
  • Jason
    October 30, 2007 at 7:49 pm
    Thanks Scot…the only problem is my screen res is already at its highest setting…hmmm
