Activity Forums Adobe After Effects How do you get Particular to move around a 3D flat plane.
  • How do you get Particular to move around a 3D flat plane.
    Posted by Reuben Fink on October 7, 2012 at 7:33 pm
    I’ve created a circular path that I want a Particular emitter to move along in z-space meanwhile leaving a trail that eventually connects at both ends creating a full ring. Meanwhile I’m trying to make it look like it’s going around a sphere. Is it possible for particular to travel in front and then behind a flat 3D Plane. If not than can you suggest a work around. Thanks.
    Rube
    OSX 10.6.4
    Equipment: 2.8 ghz 8 core Intal Mac Pro, 20 gig of ram
    Aps: CS5 Production Bundle, FCP Suite 2, Avid Media Composer
    Reuben Fink replied 13 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
  • Tudor “ted” jelescu
    October 7, 2012 at 7:46 pm
    https://aescripts.com/sparticular/
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Vishesh Arora
    October 8, 2012 at 6:24 am
    Reuben
    May be the Far Vanish and Near Vanish feature may work.
    Her is the tut for it:
    https://www.redgiantsoftware.com/videos/redgianttv/item/313/
    Vishesh Arora
    VFX and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • John Cuevas
    October 8, 2012 at 11:43 am
    If it’s a 3D plane, with 3d enabled then you would twirl open visibility > obscuration layer and choose the 3d Plane. Now your particles will interact with that layer.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Reuben Fink
    October 8, 2012 at 4:40 pm
    Thank you for all your suggestions. I’ll take a stab at them all and see what works best.
    OSX 10.6.4
  • Reuben Fink
    October 9, 2012 at 7:38 pm
    Ok so I found success with using an obscuration layer.
    Check here:
    https://youtu.be/Fb-sjS3fZw0
    I’m happy with the look. The only problem is that at full rez the edges of the obscuration layer are sharp and aliased looking and doesn’t blend in. Is there a way to soften the obscuration layer? I tried putting a soft blur on the layer but it didn’t do anything.
    OSX 10.6.4
  • Tom Daigon
    October 9, 2012 at 10:04 pm
    To precomposing the obscuration layers. Then add the blur to the precomped clip.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Reuben Fink
    October 10, 2012 at 8:38 pm
    I’ve tried that to no avail. Have you had success with this method?
    OSX 10.6.4
