Activity › Forums › Adobe Premiere Pro › How do you get handles on extracted Audio – Premiere to Audition?
Posted by Scott Clements on May 20, 2015 at 6:11 pmHow do you get handles on extracted Audio – Premiere to Audition?
Film Editor, London UK
http://www.scottclementseditor.comTero Ahlfors replied 11 years, 4 months ago 4 Members · 4 Replies -
Jeff Pulera
May 20, 2015 at 7:57 pmLengthen the audio clip on Premiere timeline BEFORE you click “Edit in Audition”. When you select that, it renders a new clip from the timeline clip, so that is the exact length you will be living with moving forward.
Jeff Pulera
Safe Harbor Computers -
Paul Neumann
May 20, 2015 at 9:41 pmYeah, I always cut a little long in Prelude and/or the Source Monitor. Trim in the timeline and there’s always enough to use in Audition.
Scott Clements
May 20, 2015 at 10:00 pmThanks for confirming my fears, gentleman. “Edit in Audition” can sometimes save me, but it is a very messy workflow. It doesn’t really allow you to edit your audio before you fix it and then you better fix it right, because there’s really no going back.
http://www.scottclementseditor.com -
Tero Ahlfors
May 21, 2015 at 6:12 amIf you are sending the whole sequence to Audition you can set the audio handles in the edit in Adobe Audition setting window.
