Activity › Forums › Apple Motion › How do you feather imported video frame edges?
Posted by Tangier Clarke on October 18, 2005 at 5:15 pmI’ve imported several video clips and want to feather the edges similar to how FCP feathers video. There seems to be no simple way of doing this in Motion 2.
Tangier
Jim Kanter replied 20 years, 11 months ago 4 Members · 5 Replies -
Jayson Steckler
October 18, 2005 at 7:19 pmuse the Mask tool to add a rectangle mask and adjust the feather to your liking.
Doyle Rockwell
October 18, 2005 at 7:32 pmAfter drawing the mask, you can also use the Channel Blur filter (Alpha only) for a smoother feather than the mask-shape’s feather.
Tangier Clarke
October 18, 2005 at 7:41 pmI’ve tried that before, but there is no parameter for feathering when I select the mask.
Jayson Steckler
October 18, 2005 at 8:56 pmDid you draw a mask? (it’s the to the right of the Text tool) The bottom parameter for a drawn mask is Feather in both the Inspector and the Dashboard.
There’s a great chapter on masking in the user manual…. (Starts at page 851 if you’re using Motion 2)
Jim Kanter
October 20, 2005 at 7:44 pmYou can also add an image mask to any object and use any object with alpha (edges) to become that mask. You can continue to modify the original shape object (including animating it) and have it immediately update the mask.
Example:
Add a video clip to the project.
Add a rounded rectangle to the project (from Library > Shapes).
Manipulate it so it is the right shape for the mask.
Select the video clip and choose Object > Add Image Mask.
Drag and drop the rounded rectangle object onto the Image Mask element of the video clip.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com
