Activity › Forums › Adobe After Effects › how do you export lower thirds
Posted by Bryanisfishing on March 4, 2006 at 9:19 pmwhat are the settings.
Bryanisfishing replied 20 years, 6 months ago 4 Members · 5 Replies -
Steve Morris
March 5, 2006 at 3:13 amWhen going from AE to Premiere, I use:
Quicktime, RGB + Alpha, Premultiplied (matte),Format Option compression set to Animation
You could also use a png or tga sequence.
Bryanisfishing
March 5, 2006 at 5:54 pmWHAT ARE THE STANDARDS FOR LOWER THIRDS.
IE. HOW FAR FROM THE BOTTOM DOES IT HAVE TO BE .. ARE THEY INSIDE THE “TV BORDERS” CAN SOMEONE LIKE SHOW ME A PICTURE OF IT.
how it should look in IE? (like a screen shot)
thank you so much
Steve Roberts
March 5, 2006 at 6:14 pmOuch! No shouting! 🙂
I am not aware of any standards. I just make sure any text is within the title safe area, which is the inner rectangle of the two safe areas.
After that, it’s an aesthetic thing. If you want to make sure non-textual graphics are seen, make sure they’re within the action safe area (the outer rectangle).
