Activity › Forums › Adobe After Effects › How do you export a still image in AE?
Posted by Peter Jun on December 2, 2007 at 5:32 pmI want to export a single frame to a jpg. The only image export option I see is Image Sequence but don’t want to export the whole sequence.
Ashish Luthra replied 6 years, 3 months ago 5 Members · 6 Replies -
Steve Roberts
December 2, 2007 at 5:54 pmSorry … I just use the shortcut, so I gave you the wrong location. It’s composition>save frame as>file.
Jerzy Drozda jr
December 2, 2007 at 8:27 pmTheres also a plugin to copy the current frame to clipboard and for example paste it to Photoshop. I used it in one of my tutorials. See it in action here:
https://maltaannon.com/after-effects/simple-object-removal/
maltaannon.com – Free After Effects Video Tutorials and more
Blake Howard
February 22, 2012 at 4:32 amGo to the frame that you want to export so that it is shown in the Composition panel.
Do one of the following:
To render a single frame, choose Composition > Save Frame As > File. Adjust settings in the Render Queue panel if necessary, and then click Render.
To export a single frame as an Adobe Photoshop file with layers, choose Composition > Save Frame As > Photoshop Layers. -
Ashish Luthra
June 13, 2020 at 5:55 pmFirst, take your Playhead to frame you want to Export & then
Go to Composition(before layer tab)>Save Frame As>File>output mode should me JPEG Sequence if you want jpeg format.
