Activity Forums Apple Final Cut Pro Legacy How do you export a project as a DV quicktime movie in mono?
  • How do you export a project as a DV quicktime movie in mono?
    Posted by Jimmy Guarasci on September 12, 2005 at 6:10 pm
    In FCP HD and below it was easy to export a project as a DV quicktime movie with 48K Mono. Now in FCP 5 I can not find out how to do it? I used to just go to export, quicktime, custom. Then into the advanced settings of the audio and choose Mono. But their is no longer an advanced option for audio. Any help would be truly appreciated.
    Bret Williams replied 21 years ago 2 Members · 1 Reply
  • Bret Williams
    September 12, 2005 at 6:48 pm
    As far as I can tell you need to use QT conversion export, and choose mono under the audio settings in the standard QT export dialog box.
    Or you could pan everything to center in your timeline and export QT movie.
