Activity Forums Adobe Premiere Pro How do you enable safe margins if it’s grayed out?
  • How do you enable safe margins if it’s grayed out?
    Posted by Wesley Dysart on February 19, 2009 at 4:41 pm
    I’m trying to work on a film for TV broadcast but for some reason I cannot enable safe margins. It’s grayed out. I can see where the manual says to enable them, but the manual doesn’t say what to do if you are unable to enable them.
    Anybody know how to remedy this?
    -Wesley D.
    Mark Whitney replied 17 years, 6 months ago 3 Members · 3 Replies
  • Vince Becquiot
    February 20, 2009 at 12:13 am
    That’s odd. Sounds like a bug somewhere. If you can’t figure out let me know and I’ll send you a transparent template to throw above your timeline. Just let me know the resolution and aspect ratio you are working with.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Wesley Dysart
    February 20, 2009 at 4:35 pm
    One of our other editors was able to login to the computer remotely and turn them on. It seems there is a button that will toggle the margins on and off, but the drop down menu is still gray. Very strange, but at least it’s working, halfway.
    Thanks for the reply!
    -Wesley
  • Mark Whitney
    February 24, 2009 at 2:55 am
    I can’t say for sure if this is the problem, but check under:
    Project> Project Settings> Capture> Properties, then check that the Desktop Preview Acceleration is set to None.
    I had a similar problem with BlackMagic Design capture hardware on a MacPro running Windows XP and using the standard nVidia GeForce 7300 GT video card.
    Mark
