Activity Forums VEGAS Pro How do you edit multi cameras on time line?
  • How do you edit multi cameras on time line?
    Posted by Mahesh Upadhyaya on May 10, 2005 at 12:29 pm
    The subject-line does not define my question precisely so let me explain.
    Say I have 2 events of a conference lined up on the time line.
    One camera is on the speaker and one on the audience.
    Whilst I am selecting cameras on the time line (with Excaliber of course), I see shots from other camera(s) which may make good cut-aways later on in the edit. It would be nice to mark and file away that segment as a possible cut-away.
    So my question is, how do you log likely cut-aways as you are doing your main multi camera edit? Say you are sitting with a client. You do not want to interrupt the work flow too much. You notice a likely cut-away which might come in useful later on. How would you file away that bit of cutaway without inerrupting the workflow too much.
    I would be most interested in how you would do it.
    Regards
    Mahesh
    https://www.crestvideo.co.uk
    Mahesh Upadhyaya replied 21 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Timothy Duncan
    May 10, 2005 at 2:24 pm
    Simply split the clip you want to save and right click choosing “sub-clip” — the subclip will be placed in the bin you have open.
    Another way is to right click on the clip you want and choose to “open in trimmer” — mark the area you like and hit the “sub-clip” button. This way will prompt you for a name, then place the subclip in your open bin.
    td
  • Edward Troxel
    May 10, 2005 at 2:28 pm
    Another thing you could do is place a “comment marker” at that location. Manually add a marker there (press M) and make the FIRST character a > followed by any description you like. All markers beginning with > will be ignored by the Multi-Cam Wizard. If you choose to “remove markers”, all markers EXCEPT the comment markers will be removed. Then you can easily see those specific sections.
    Edward Troxel
    JETDV Scripts
  • Mahesh Upadhyaya
    May 10, 2005 at 2:42 pm
    Timothy
    Splitting the clip becomes messy if there are 4 or more camera tracks and associated audio tracks.
    I like the idea of opening in the trimmer and making sub clips. I have not really explored the use use of sub clips yet.
    Edward
    I have, on occassions, used ‘comment’ markers to mark posible start point of usable clips. My trouble is, I run excalibur to assemble small portions at a time. So first time I run Excalibur, the comment markers are saved but ‘>’ removed. So next time I run the script, the markers are removed.
    Regards
    Mahesh
  • Edward Troxel
    May 10, 2005 at 3:08 pm
    That’s true, the “>” symbol is automatically removed as the other markers are deleted. Maybe that should be optional???
    Edward Troxel
    JETDV Scripts
  • Mahesh Upadhyaya
    May 10, 2005 at 3:13 pm
    That would be perfect Edward!
    I presume one would only need to remove the ‘>’ before rendering to MPEG2 for chapter points.
    Ohh, that remids me, must order the upgrade to 4.0!!
    Regards
    Mahesh
  • Gary Kleiner
    May 10, 2005 at 4:15 pm
    [mahesh] “how do you log likely cut-aways as you are doing your main multi camera edit? “
    I find it quickest to load the media into the trimmer where I can zip through it and just pop the cutaways into their own track that I can draw from as needed.
    Gary Kleiner
    Vegas Training and Tools.com
  • Mahesh Upadhyaya
    May 10, 2005 at 4:46 pm
    Thanks Gary
    That is what I would normally for cutaways ( although I do it on time line).
    I was thinking more of 2 or more continuous streams of video, such as a conference, where I would play the time line, placing markers and then using Excalibur to assemble camera selections.
    Now let say I have selected cam-1 but notice an interesting segment on cam-2. It would be nice to put a place holder there. I could
    1-open cam-2 clip in trimmer and make sub clip – as Timothy suggested.
    2-Place a comment marker as Edward suggested.
    Both suggestions are good.
    Edward volunteering to make removal of ‘>’ symbol is even better:)
    Regards
    Mahesh
  • Mahesh Upadhyaya
    May 11, 2005 at 9:33 am
    Only yesterday, Edward suggested the above and today he tells me ‘It’s Done’.
    Thanks Edward.
    Regards
    Mahesh
