Activity › Forums › Adobe Premiere Pro › How do you do your backups?
Posted by Joel Arvidsson on December 16, 2011 at 2:48 pmTrying to improve my workflow and wonder how you guys is doing your backup.
Manually, just mirror the raid, time machine…etc.Bob Woodhead replied 14 years, 9 months ago 4 Members · 6 Replies -
Ian Blackburn
December 16, 2011 at 5:01 pmI run MacPro with a Time Capsule which is in a different building – It’s BRILL!
Ian B
Bob Woodhead
December 17, 2011 at 1:52 amWork in progress lives on a RAID 5. There are standard template folders (camera files, audio, edit files, renders, do not archive, client review, etc) that are copied into every new project. When done, some files are deleted (eg: do not archive, renders). Remaining files are copied onto a RAID 1 (mirror raid), then catalogued into a database (Disktracker on Mac). When RAID pair are full, onto shelf. Files can be quickly found again via Disktracker.
About 15 sets of HDD pairs on shelf now. Have had 1 drive fail, but 2nd was good, so simply copied onto new drive to maintain mirrored backup.
Works for me until “the next big thing” happens in storage.
“Constituo, ergo sum”
Bob Woodhead / Atlanta
Quantel-Avid-FCP-3D-AFX-Crayola
Panasonic HPX500/AF100 -
Chris Borjis
December 20, 2011 at 5:55 pmI use 500GB external hard drives for client back ups. I don’t go any bigger so they span less, have less reliance on just a few drives.
For system backup, every 3-4 months I make a system disk image with carbon copy cloner and store that on a different external drive.
Joel Arvidsson
December 20, 2011 at 10:06 pmI have been changing my structure to many times now. Im going to make a new better solution and stick with it. So it would be interesting to se how more creative people is sorting your files/naming.
Im interested in both how you index files
Date_client_project_scene_script version_take nr.file extension
Date_project_kamera nr_cam_camera generated name.file extensionand what is you file structure.
Thanks Bob for including your template folders.
Bob Woodhead
December 21, 2011 at 1:42 pmHere’s my template list. These are copied into a top level folder on the RAID 5 that has the project’s name. By using a database that allows multiple search parameters, it’s VERY fast to find any kind of file from years back. For example, criteria 1 = folder name = BigCommercial , criteria 2 = folder name = art, criteria 3 = filename = logo. Badda bing, file found. I’ve used this method since the days of archiving data on CD’s, and it’s migrated perfectly as the media evolves.
Bob Woodhead
December 21, 2011 at 1:46 pmThis method also lets you do without the “Date_client_project_” prefix on every file. 😉 Of course, I often create subfolders when I feel like it – eg, “art” folder might contain “client stills”, or whatever.
I do need to mention in my search parameter sample above, “folder name” should really be “ancestor name”, so that random subfolders are searched, as outlined in this post.
