Activity › Forums › Adobe Photoshop › How do you do this?
  • How do you do this?
    Posted by Craig C smith on February 9, 2009 at 6:18 pm
    I hope I explain this. I am looking to take multiples jpegs (100) and put it together on one sheet. I am not sure on how to do it. I want to size each Jpeg of equal size to fit. I guess I have to set up some type of grid. I am not sure how to do that. and if there is an automated way of placing the jpegs. Thanks in advance.
    Jeff Kelley replied 17 years, 7 months ago 2 Members · 3 Replies
  • Jeff Kelley
    February 13, 2009 at 5:41 pm
    Are you using Photoshop or Photoshop Elements? Check to see if you have Contact Sheet under File/Automate, that should do all you want.
    http://www.willinois.com
  • Craig C smith
    February 13, 2009 at 7:54 pm
    No I am using Photoshop CS4. I did it the hard way. I made each jpeg 2″ by 2″ 72 DPI and then place each one indiviually on a large background sheet. It took a couple of hours. I was wondering how to automate something like this. Thanks for you response.
  • Jeff Kelley
    February 13, 2009 at 9:37 pm
    If you have SC4, you can make contact sheets. That is the way to automate it. I use it everyday.
