Activity › Forums › Apple Final Cut Pro › How do you cut the master by referring to a timecode list without the timecode being burned into the picture?
  • How do you cut the master by referring to a timecode list without the timecode being burned into the picture?
    Posted by Tim Wilde on November 23, 2016 at 5:15 am
    I gave my friend a copy of the raw footage of her event with timecode burned in so she could pick the parts she wants me to string together into a simple edit. I added the timecode window in Compressor.
    Now I’m sitting here realizing that once I chop out the first segment the remaining material in the timeline will slide forward, causing her timecode notes to be off. It occurs to me that before editing I could add a continuous title consisting of timecode, which I would somehow cut along with the actual video, but surely there’s a better way.
    Oliver Peters replied 9 years, 10 months ago 6 Members · 8 Replies
  • 8 Replies
  • Noah Kadner
    November 23, 2016 at 5:31 am
    Just reimport and then overcut her burned in version edits with the matching raw footage.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Jeff Kirkland
    November 23, 2016 at 6:03 am
    I usually do this by putting the timeline and the timecode generator in a compound clip. The timecode overlay will stay in place as I cut the compound clip. Once done I just go into he compound clip and delete or disable the timecode.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Oliver Peters
    November 23, 2016 at 1:22 pm
    You can also work in reverse order, doing the last notes first and so on.
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Andreas Kiel
    November 23, 2016 at 2:03 pm
    You can work like Oliver suggested or replace the uneeded parts by a gap.
    – Andreas
    Spherico
    https://www.spherico.com/filmtools
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
  • Michael Sanders
    November 23, 2016 at 10:24 pm
    Start from the end and cut backwards.
    Michael Sanders
    London Based DP/Editor
  • Michael Sanders
    November 23, 2016 at 10:25 pm
    Apologies Oliver – I hadn’t seen your reply!
    Michael Sanders
  • Jeff Kirkland
    November 23, 2016 at 10:40 pm
    With my compound clip method, you can turn the timecode overlay on/off to check your cuts (useful when the client says you cut in the wrong place) and you can cut from the start or the end of the clip – although I almost always start from the end and work backwards.
  • Oliver Peters
    November 24, 2016 at 4:10 pm
    Not a problem. It’s quite alright.
    Oliver
    Orlando, FL
