Activity › Forums › Apple Final Cut Pro › how do you create this effect? ghost effect?
  • Loren Risker
    January 29, 2013 at 10:59 pm
    To get you started:
    Duplicate the portion of your clip where you want the ghosting to occur. Add it directly on top of the original clip (command-c to copy, alt-v to connect to the storyline)
    Slip it forward or backwards a few frames. Change the opacity of the top clip to around 50%.
    OutOfFocus.TV – Original series, music videos, and entertainment for your couch.
  • John Fishback
    February 12, 2013 at 5:45 pm
    If you have Motion 5 it has a Trail Effects that will do what you want. If you don’t have it, Google “Trail Effect for FCPX” and see what pops up.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.7.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.7, Motion 5.0.6, Compressor 4.0.6
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
