Activity Forums Adobe Premiere Pro How do you copy entire metadata columns and paste to another column?
  • How do you copy entire metadata columns and paste to another column?
    Posted by Scott Clements on April 28, 2015 at 11:42 pm
    How do you copy clip names in name column and paste to another column (‘description’ for example)? I want to rename all clips in a premier project, but I really dislike that there’s no column that actually shows the file path and that you have to rely on Premiere’s under-the-hood links to the original material. So, I want to do what I’ve done in Avid- copy the names of all clips and paste into another column. I can’t figure out how to do this quickly. Instead, I have to do it one at a time. Anyone know how to do this all in one go?
    Film Editor, London UK
    http://www.scottclementseditor.com
    Scott Clements replied 11 years, 4 months ago 2 Members · 2 Replies
  • Alex Udell
    April 28, 2015 at 11:49 pm
    Scott…
    wait…
    project panel menu > metadata display >
    search path
    enable it
    move column to a more convenient view position…
    now you can rename the main filed without worrying about not remembering the original file name…does that help?
    so the copying may not be necessary.
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Scott Clements
    April 29, 2015 at 12:25 am
    Thanks, Alex.
    I see “Media File Path”. It’s not quite as rock solid as having the original file name, as a path can change (and sometimes accidentally the original file name can be lost), but this is definitely good to know about.
