Activity › Forums › Adobe After Effects › How do you copy all effects from one layer to another?
Posted by Larry Watts on September 6, 2005 at 6:16 pmI’ve been away from AE for a while…
Larry
LSW
Kurt replied 21 years ago 4 Members · 3 Replies -
Lava
September 6, 2005 at 7:06 pmyoucan copy the effects of one layer to another by copyingthem from the floating effects window – however, keyframes don’t go with it – you could also duplicate the layer, select the dupe, and drag your new layer onto that holding the option key which should replace only the footage, leaving all effects, including keyframes the same – the trick is to have the dupe layer selected when you option-drag – does that help?
John Dickinson
September 6, 2005 at 8:11 pmAnother way is to select all of the effects in the Effect Controls window and choose “Save Animation Preset” from the Animation menu. This will save the effects and any keyframes applied.
JD
John Dickinson
Motionworks
https://www.motionworks.com.au -
Kurt
September 7, 2005 at 10:28 am1. Copy/paste the effects from the effect window
2. Copy/paste the keyframes
