Activity Forums Apple Final Cut Pro How do you convert using MPEG Streamclip?
  • How do you convert using MPEG Streamclip?
    Posted by Ignacio Holiday on May 5, 2012 at 4:30 am
    I’m trying to convert a file for editing in Final Cut Pro X using MPEG Streamclip. I followed the instructions in a tutorial, which was to set the output as Apple ProRes 422 LT and the pixel dimensions at 1920×1080(unscaled). After I converted it this is the file info I got for the new converted file when I hit Command+I in QuickTime
    FPS: 29.92
    Data size: 22.71 GB
    Data Rate: 69.92 mbit
    Current size: 1440×810 pixels
    WTF? Are the dimensions I picked totally wrong? How did it swell to 22 GB? And it wouldn’t even play in Final Cut anyways.
    I must be missing something obvious, but I am having the hardest time just converting a simple file so I can edit it.
    Tony Brittan replied 14 years, 4 months ago 3 Members · 2 Replies
  • Tom Wolsky
    May 5, 2012 at 6:04 am
    What else does it say? Start at the top and give the whole thing.Ignore current size. BTW, what was the original size of the media you were converting?
    All the best,
    Tom
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
  • Tony Brittan
    May 5, 2012 at 2:17 pm
    If you’re using FCP X you don’t need to use MPEG Streamclip. When you import a file, X will transcode it to a correct ProRes codec for you according to how you set up the import.
