Activity › Forums › Apple Final Cut Pro Legacy › how do you control the light ?
  • how do you control the light ?
    Posted by Antonio Atzei on June 12, 2007 at 12:22 pm
    I may been asking the wrong question before so here I go again.
    Let`s say that you want to cut down the ammount of light in your final project. How should I go about? Apparently every attempt give`s me the same outcome.
    A- cutting the ammount of whites or mids
    B- cutting down the opacity
    I also tried some filters with no success
    The bottom line is that I need to lower the luminosity of the clip and make sure that during output to sd dvd keeps that setting.
    Any suggestion please, or point e in the right direction.
    The dvd looks fantastic it`s only to bright.
    ciao
    Antonio Atzei
    Richard Martz replied 19 years, 3 months ago 2 Members · 3 Replies
  • Richard Martz
    June 12, 2007 at 12:52 pm
    I personally would not want to lower the opacity. Typically we color correct scene by scene. I almost never apply a single setting to a whole project. The methods you are using seem to be correct. Lowering the Highs (whites) and Mids will lower the percieved brightness (luminosity) of a scene. You might want to use a filter such as a broadcast safe filter and see if that improves the result. But again you’ll have to apply that scene by scene. What seems to be the problem that you are correcting?
    It sounds like much of the project may have been over-exposed. When we shoot in the field we reqularly under expose slightly. That way it prevents loss of detail in highlighted areas. And as a side benefit it prevents the problems you may be experiencing now.
    Richard Martz
    MagicMartz Media
    Final Cut Pro HD
    Kona LH
    After Effects
    PhotoShop
    Illustrator
    Lots of other Fun Stuff!
  • Antonio Atzei
    June 12, 2007 at 1:08 pm
    Richard
    Txs for your prompt reply
    Yes I did try the broadcast safe filters and also level filters also hsv filters… well I tried many things…
    So if the footage was overexposed…. how do I cut down the luminosity ?? any experiments you can suggest?
    Txs
    ciao
    Antonio Atzei
  • Richard Martz
    June 13, 2007 at 5:45 am
    Send me one still frame of your problem video via e-mail and I’ll figure out a setting and send it to you. rmartz@magicmartz.com
    Richard Martz
    MagicMartz Media
    Final Cut Pro HD
    Kona LH
    After Effects
    PhotoShop
    Illustrator
