Activity › Forums › Apple Final Cut Pro Legacy › how do you control the light ?
  • how do you control the light ?
    Posted by Antonio Atzei on June 12, 2007 at 12:24 pm
    I may been asking the wrong question before so here I go again.
    Let`s say that you want to cut down the ammount of light in your final project. How should I go about? Apparently every attempt give`s me the same outcome.
    A- cutting the ammount of whites or mids
    B- cutting down the opacity
    I also tried some filters with no success
    The bottom line is that I need to lower the luminosity of the clip and make sure that during output to sd dvd keeps that setting.
    Any suggestion please, or point e in the right direction.
    The dvd looks fantastic it`s only to bright.
    ciao
    Antonio Atzei
    Rafael Amador replied 19 years, 3 months ago 4 Members · 3 Replies
  • Dunwoody Lampton
    June 13, 2007 at 8:05 pm
    I use a DataVideo DAC-15 bi-directional digital/analog converter between my Betacam SP source deck and my PowerMac G5. The DAC-15 has controls for adjusting brightness, contrast and chroma for source material before it enters the G5.
  • Russell Lasson
    June 13, 2007 at 8:41 pm
    You can use the 3-way color corrector or the levels filter in FCP. You really just need to experiment with it until it looks right to you. Sometimes color correction is counter intuitive. Like if it’s to bright, instead of turning now the highlights, you might make the blacks or mid tones darker. It really takes practice on the best way to get what you want.
    -Russ
  • Rafael Amador
    June 14, 2007 at 5:16 pm
    Antonio,
    you can have a look to the “Levels’ filter.
    Where do you say that the DVD look to brighting? In a TV? In a Mac? PC? CRT monitor?
    Depending wher you watch it can look very different. In fact if you want a movie to look perfect in these different screens, you would need to make 4 different movies.
    If iyour problem is when you play a DVD in a TV set, have a look to the gamma filter in Compressor.
    rafael
