Activity › Forums › Apple Final Cut Pro Legacy › How do you completely UnInstall FCP Studio
  • How do you completely UnInstall FCP Studio
    Posted by Jonathan Flookes on July 18, 2006 at 8:28 pm
    I need to Completely uninstall FCP so i can enter in a New Serial Number. Right now its on 2 machines connected by a network. They can not run at athe same time which is a problem, so I got a new set and its not allowing me to instal the new Serial. Any help would be apppreciated.
    PS- Ive already used a prrgrams like cleanapp and zappapp, and i have also deleted its reciepts and its files in the preference folder. None of it is working.
    Jonathan
    Jonathan Flookes replied 20 years, 2 months ago 3 Members · 3 Replies
  • John Pale
    July 18, 2006 at 9:02 pm
    The system ID’s are in
    Library/Application Support/ProApps
    try deleting those
    There are also 2 files in Library/Preferences called com.RegFinalCutPro.plist and com.RegFinalCutStudio.plist which may also relate to this. Try deleting those, too, if the above does not work.
  • Rennie Klymyk
    July 20, 2006 at 5:31 am
    Might you have to log off the network?
    “everything is broken”
  • Jonathan Flookes
    July 20, 2006 at 5:35 am
    Thank you guys for your help. It looks like the one thing I needed to delete was the system I.D.
    Thanks foe helping me out.
    Jonathan
