Activity Forums VEGAS Pro How do you combine video footage with different resolutions?
  • How do you combine video footage with different resolutions?
    Posted by John Lee on September 1, 2014 at 12:26 am
    I use Sony Vegas to make highlight videos, and usually the footage is from my Sony Camcorder. The resolution of my Vegas project is usually 1920x1080x32, 29.970i.
    I have to use some footage from someone else, and it’s grainy, non-HD stuff. It is 640x480x12.
    So when I place the non-HD film on the video track, it shows up with black bars on the side.
    Is it possible to do something to the non-HD film to get rid of the black bars? I realize it will likely resize the non-HD film and I will lose some stuff on the periphery, but that is preferrable to having the ugly black bars.
    I have no idea how to do it. Any help would be greatly appreciated. Thanks.
    John Rofrano replied 12 years ago 2 Members · 5 Replies
  • John Rofrano
    September 1, 2014 at 12:44 am
    [John Lee] “Is it possible to do something to the non-HD film to get rid of the black bars?”
    Open Pan/Crop on the Event. Right-click in the Pan/Crop windows and select Match Output Aspect and the black bars will be gone.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Lee
    September 1, 2014 at 2:06 am
    Thank you very much. For some reason, following your directions still leaves a sliver of black on both edges. But pulling the crop tool works proportionally and I can reduce it a few notches to make it clean.
  • John Rofrano
    September 1, 2014 at 2:09 am
    [John Lee] “For some reason, following your directions still leaves a sliver of black on both edges.”
    Does the original footage contain a sliver of black? Many analog sources have some black pixels on the sides and pulling in the crop is exactly how you should compensate for this.
    ~jr
  • John Lee
    September 1, 2014 at 3:09 am
    I think so. Regardless, what I did (and what you confirmed) worked perfectly.
    Thank you for taking the time to help out.
  • John Rofrano
    September 1, 2014 at 11:15 am
    You’re welcome. Glad I could help.
    ~jr
