Activity Forums Avid Media Composer How do you color correct a multi cam sequence?
  • How do you color correct a multi cam sequence?
    Posted by Jana on October 30, 2005 at 4:08 pm
    I have grouped two clips together to go into a sequence. I have about 200 edits going from camera a to camera b, when i try to apply a color correct on b camera, it applies an effect to the whole sequence containing both cameras, but i just want the effect applied to one camera (one clip), when i am in color correction mode it does not recongize multi camera mode and just instead recognizes one entire sequence. any way to change this rather then applying an effect to every edit (which would be 200 times)
    thanks!
    Jana
    Alex Udell replied 20 years, 10 months ago 3 Members · 2 Replies
  • Michael Phillips
    October 30, 2005 at 9:02 pm
    Make sure you don’t have a top track highlighted when color correcting. Make sure the track of the clips is the highlighted and active.
  • Alex Udell
    November 2, 2005 at 1:18 am
    I thinbk it depends on the “level” of Avidyou are on?
    Symphony has some nice relational cc to help you out…
