Activity Forums Adobe Premiere Pro How do you Change the Color of an Illustrator File in Premiere Pro?
  • How do you Change the Color of an Illustrator File in Premiere Pro?
    Posted by John Stanowski on February 20, 2019 at 6:18 pm
    I have a logo brought into my project as an .ai file.
    Back in AE, I was able to change the color with the Fill Effect.
    But I can’t find an equivalent in Premiere Pro.
    Is there a way to generate a solid color over an Illustrator in Premiere?
    2013 Intel MacPro
    3.5 GHz 6-Core Intel Xeon E5
    64 GB 1866 MHz DDR3 ECC
    AMD FirePro D500 3072 MB
    Software OS X 10.14.3
    Adobe CC
    John Stanowski replied 7 years, 6 months ago 4 Members · 6 Replies
  • John Heiser
    February 20, 2019 at 7:04 pm
    You could put a Color Matte on one track and the AI file on another, and use Track Matte Key on the color matte pointing to the track with the AI file. To make that less clunky to work with, nest those two clips together.
    Or hey – if you have the full CC subscription, open the file in Illustrator. ????. Just kidding – I can see the need for being able to change it from within Premiere.
    John Heiser
    Senior Editor
    o2 ideas
    Birmingham
  • Tero Ahlfors
    February 20, 2019 at 7:33 pm
    Or call the designer.
  • Jerry Wise
    February 20, 2019 at 7:39 pm
    You could use “Change To Color” . I use it all the time.
  • John Stanowski
    February 20, 2019 at 7:56 pm
    Thanks, I’ll look into this. I’m more of an After Effects guy so there’s a lot to get used to here in PPRO.
    2013 Intel MacPro
    Adobe CC
  • John Stanowski
    February 20, 2019 at 7:57 pm
    I did find the Change to Color effect but it doesn’t seem to do anything. But, since you’ve said you use it all the time, I’m sure I’m just not using it correctly. At least now I have a lead. I’ll research this effect now. Thanks!
    2013 Intel MacPro
    Adobe CC
  • John Stanowski
    February 20, 2019 at 7:59 pm
    Ah, Eureka! A winner!
    I got the Change to Color effect to work when I Change: Hue, Saturation & Color. The default settings didn’t do anything so that’s why I was stumped.
    Thanks again. This is exactly what I was looking for.
    2013 Intel MacPro
    Adobe CC
