Activity › Forums › Maxon Cinema 4D › How do you animate cloner visibility with timing offset?
  • Kouraib Abdmalek
    April 5, 2024 at 10:05 am
    Hi George,
    I think that using the shader effector in the offset may be useful to you to achieve this. It is powerful because it has multiple options to control the offset in a more smooth way than Step and others. I have put a link below about this. Please watch after the seventh minute and at the end of the video is a feature that I think is useful to what you are look forward. Also, I wonder if you can use more than one Effector to control offset, such as using Setp and Shader, or Plain then making one of them control movement and the other control visibility I think this will give you stronger options for controlling the animation.
    https://youtu.be/_7NKwdiBIUc?feature=shared
