Activity Forums VEGAS Pro How do you add the extras to DVDA?
  • How do you add the extras to DVDA?
    Posted by Paul Gregory on October 28, 2006 at 10:39 pm
    I burned a project last night & the results are OK except for one thing. Since the project was made up 100% of digital photos’ that I had used the pan/crop tool on I thought that it would be a good idea to include on the disk the folder with all of the original pictures since there was lots of room left available on the disk. Try as I might I was unable to include these extras using DVDA 3. I have used this feature before.
    I go to the DVDA’s properties tab to add the route to the picture folder all that comes up is is a box that says general & summery which has no place to enter the necessary data. The same thing when I try the optimize tab, no place to enter this data. Does anyone have any idea as to what I may have done wrong?
    Thanks in advance
    Ted Snow replied 19 years, 10 months ago 3 Members · 3 Replies
  • Gary Kleiner
    October 29, 2006 at 12:01 am
    In the Properies dialog there are two tabs: Properties and Summary.
    The Properties Tab has 4 Subtabs: Disc Properties, Copy Protection, Regions, Matering.
    Under Disc Properies is the Extras folder you are looking for.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Paul Gregory
    October 29, 2006 at 6:16 am
    I have found the problem & feel pretty stupid. It seems that I still had DVDA 2 installed & that a shortcut pointed to it. I now have the shortcut pointing to DVDA 2.
    Thanks in advance
  • Ted Snow
    October 30, 2006 at 9:04 am
    I usually just use Roxio for this. I just create a Data Disc…copy the AUDIO_TS and VIDEO_TS to the root directory of the disc…then create another folder/folders in the root directory and copy all the project files there. As long as you finalize the disc it should play on most players. I’ve never had any problems doing it this way.
    Ted
