Activity › Forums › Adobe Premiere Pro › How do yo remove normalisation gain?
  • How do yo remove normalisation gain?
    Posted by Scott Clements on February 20, 2015 at 2:45 pm
    I can’t seem to figure out how to do this. For example, let’s say you normalise a bunch of different audio clips after you’ve done an edit – with all sorts of little chopped up, relatively silent little bits. After normalisation gain is applied, you get all these pieces with ridiculously loud room tone. I can’t figure out how to remove this normalisation after the fact. What’s the trick? I am a total Premiere newbie.
    Film Editor, London UK
    http://www.scottclementseditor.com
    Scott Clements replied 11 years, 6 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    February 20, 2015 at 2:54 pm
    I haven’t used that but I guess it makes volume keyframes on the audio? Right click -> remove effects.
  • Scott Clements
    February 20, 2015 at 3:00 pm
    “Remove Effects” does not work, unfortunately. It’s a real head-scratcher. In FCP 7, normalisation gain was an effect that was applied and you simply removed the effect. Premiere’s implementation seems to be different.
  • Charlie Austin
    March 10, 2015 at 5:14 am
    [Scott Clements] “Premiere’s implementation seems to be different.
    just select the clip, hit G, and set the peaks back to 0…
    ~ My FCPX Babbling blog ~
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Scott Clements
    March 10, 2015 at 1:20 pm
    Thanks, Charlie. Found that out a while back. Sorry, should have updated here.
