How do u get audio to match…
Posted by Herr on May 10, 2005 at 12:02 amhow do you get audio to match the short clip i put into the theme for page properties on dvda2? thanks, john
Edward Troxel replied 21 years, 4 months ago 4 Members · 10 Replies -
Peter Wright
May 10, 2005 at 12:43 amInclude the audio in the clip you’re using.
Peter Wright
Perth, Western Oz
http://www.allroundvision.com.au -
Herr
May 10, 2005 at 2:13 amoops i should have said add music to match… when i tried this the theme goes to black and the music keeps on playing to the end. thanks, john
Herr
May 10, 2005 at 2:44 amdoes that mean i have to go back to movie maker and add specific music to that clip? thanks, john
Wobblyboy
May 10, 2005 at 3:48 amYou don’t have to, just set end points for clip. However it would be better if they matched before rendering as you will still get whole thing on DVD.
Herr
May 10, 2005 at 5:45 pmi have managed to add the music. as you said the image stopped but the music continues with a black screen. i can’t fig. out how to edit or shorten the music clip. i think it is time to buy those video tuturials!
Edward Troxel
May 10, 2005 at 6:35 pmPlace the music on the VEGAS timeline. Create a selection area for the length of the video on the menu. File – Render AS – make sure you only render the selection area. Now put this SHORTER music file as the menu music. (you may want to fade-out the music on the Vegas timeline before rendering)
The important key is that BOTH the VIDEO and AUDIO are exactly the same length. Otherwise, the longer one will continue playing after the shorter one runs out.
Your BEST bet would probably be to render a DV-AVI file WITH audio to use as your menu background. Then you don’t have to worry about them being different lengths. Plus menus have to be encoded anyway (to add the menu options) so it should give you a higher quality menu.
Herr
May 11, 2005 at 2:51 amthank you very much. it was nice getting it to work the way i was hoping for. u guys are a great ,great help. take care, john
Herr
May 11, 2005 at 7:40 pmhi ed, i tried to register to your forum ,but , it said my e-mail was banned. are there some restrictions to your site? sorry, i didn’t see how i could send you an e-mail other than attaching it through this forum. thanks for all your help john
Edward Troxel
May 11, 2005 at 9:09 pm
