Activity Forums DVD Authoring How do they do that?
  • How do they do that?
    Posted by Nina Staum on May 19, 2008 at 5:15 am
    I need to author an anamorphic DVD that plays back letterboxed on a 4×3 TV, regsrdless of whether the menu is set to 4×3 pan and scan or 4×3 letterboxed.
    I edited on Avid Xpress DV 4.6 and I’m authoring on a friend’s Mac with Toast Titanium 8. I export from Avid as a progressive scan DV-NTSC quicktime at the native resolution. I will probably send the job out before buying any software since I’m going to be switching to Final Cut soon, but would appreciate some insight into the theory.
    -Nina
    Scott Roberts replied 18 years, 3 months ago 2 Members · 1 Reply
  • Scott Roberts
    June 14, 2008 at 3:34 am
    Output your NTSC-DV as anamorphic 16×9. In your authoring program, make sure you check everywhere that you’re intending to author a 16×9 program – authoring programs sometimes have lots of areas to check for 4×3 references. Import your 16×9 clips and make sure they are flagged as 16×9. To do a test: create a short 16×9 clip, render it out, import it into your authoring program, author the dvd then try it on a 4×3 set.
    Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
    LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
    https://www.littleblackbird.com
