Activity › Forums › Adobe Premiere Pro › How do I zoom through translucent text?
Posted by Christian Aakerhus on January 15, 2014 at 7:56 pmAllright, so I am working on a title, I know how to make the text translucent, but I want to zoom through a letter in the title, very similar to the way it’s done in this video at 01:08
https://www.youtube.com/watch?v=mE_t3fdEBAAIs this possible to achieve in Premiere Pro? So far I have tried to scale my text up at maximum, but it is not enough, as the scaling is limited. Here is what I got so far;
https://www.youtube.com/watch?v=kfU0vUejsVMBest regards,
Steve Brame replied 12 years, 4 months ago 3 Members · 7 Replies -
Christian Aakerhus
January 17, 2014 at 12:43 amI also tried to size the font to maximum, but it is not enough to make the title disappear completely.
Steve Brame
January 17, 2014 at 1:38 pmWe’ve run into this before, and had to create the text very large to start with in Photoshop, then import to PPro.
Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
“98% of all computer issues can be solved by simply pressing ‘F1’.”
Steve Brame
creative illusions Productions -
Marcin Grabos
January 17, 2014 at 4:01 pmUse magnify effect. Just make sure that “size” is large enough.
Marcin Grabos
January 17, 2014 at 4:49 pmSorry, I gave wrong advice. With magnify effect, the enlarged one will appear as additional “layer”.
So, inside Premiere, you have to make title few times bigger than your sequence dimensions, choose maximum font size to fill in horizontally, drop it to your sequence, resize down and make scaling with keyframes as you wish. If is not enough, you have to options. First is transform effect which give you another 300% zoom, or nest this title (option under right click of mouse) and then you have another 600% to the size. -
Christian Aakerhus
April 17, 2014 at 4:35 amHi again,
I had a break from this project, but I’m back on it now.
I tried to make the text large in Photoshop and imported the PSD-file in PPro, but then I don’t find any options for scaling it. Could you provide me with a more in-depth explanation on how I achieve this? Or link me the thread where this issue has been discussed before?
Thanks! -
Christian Aakerhus
April 17, 2014 at 4:38 amAlso, I have found a video which shows exactly what I’m trying to do. Check out the intro in this video.
https://www.youtube.com/watch?v=SdNZYj-Nn48 -
Steve Brame
April 17, 2014 at 11:14 amhttps://helpx.adobe.com/premiere-pro/using/motion-position-scale-rotate-clip.html
Steve Brame
