Activity Forums Apple Final Cut Pro Legacy how do I work around color space issues between FCP and AE?
  • how do I work around color space issues between FCP and AE?
    Posted by Bob Flood on April 3, 2007 at 2:51 pm
    Hi
    i have an entire show that i am doing green screen, actors and some props on a green bg. I edit the stuff, then i export to my AE guy, he keys it and gives me back a qt with alpha, and i key it over stuff….easy enough huh?
    HOWever
    when i get the stuff back from him, the colors wrong, not terribly, but enough to be annoying (and noticeable)
    we shot everything DVCPROHD, I am exporting DVCPROHD clips to my animator, he works on a pc with AE 6.5, then gives them back to me as 32 bit Animations.
    Obviously i am getting some kinda color space issues. How do i fix it? do i have to cc each animation file? IS there more info into this somewhere?
    I DID search this forum using phrases like color space and color shift, but seemed to get a lot of unrelated topics (g raids?) My producer is breathing fire, so i need to know soon.
    thanx for your help
    bee eph
    Rafael Amador replied 19 years, 1 month ago 3 Members · 4 Replies
  • Rafael Amador
    April 3, 2007 at 3:41 pm
    Hi Bob,
    Sorry I’ve never have done blue screens with DVCProHD but two possible solutions:
    – Export from AE with a YCbCr codec. Your animator can install in his PC the Blackmagic codec that are free and compatible.
    – Export just the Alpha channel from AE and make the composition in FC.
    Cheers,
    Rafael
  • Alan Okey
    April 3, 2007 at 9:26 pm
    Would working with image sequences (targas or tiffs) be a possible workaround to bypass this issue?
  • Rafael Amador
    April 4, 2007 at 6:29 am
    Targas aTiffs are RGB, so better avoid it.
    rafael
  • Rafael Amador
    April 4, 2007 at 6:28 pm
    As you said before, better to keep in the same color space. Why not Sheer 10b, YCbCr{A} 4.4.2{4}, or better 4.4.4{4}?
    rafael
