Activity › Forums › Apple Final Cut Pro Legacy › How do I use the 16×9 aspect ratio in Final Cut Pro 4?
  • How do I use the 16×9 aspect ratio in Final Cut Pro 4?
    Posted by Luthervig on November 14, 2006 at 5:17 am
    I am currently using Final Cut Pro 4 and am shooting on Sony HDR-HC1 using the HD setting. I then down convert to DV in the 16×9 format but when I begin working with my footage in Final Cut it is Letterboxed in the viewer. When I Export my final sequence it is out put to standard 4×3 Letterboxed. I know I’m doing something wrong but I don’t know what. Anybody out there ever have this problem?
    LutherVig
    Luthervig replied 19 years, 10 months ago 2 Members · 2 Replies
  • David Smith
    November 14, 2006 at 1:22 pm
    Sounds like you’re putting the clips into a 4:3 sequence. Choose an anamorphic easy set up and then open a new sequence. Also make sure the clips have the anamorphic check box checked.
    Regards,
    David
  • Luthervig
    November 15, 2006 at 3:16 am
    Thanks David I’ll check that out!
