Activity Forums Adobe After Effects How do I use scripting to select a ‘Render Settings’ template?
  • How do I use scripting to select a ‘Render Settings’ template?
    Posted by Mark Paterson on November 13, 2019 at 7:30 am
    I’m trying to write a script that will add the selected comp to the Render Queue, then select a custom ‘Output Module’ (Multi-Machine Sequence TIFF RGB) and one of the built-in Render Settings templates (Multi-Machine Sequence).
    So far though, I’ve only been able to select the Output Module. I’m using the following…
    var comp = app.project.activeItem;
    var item = app.project.renderQueue.items.add(comp);
    var outputModule = item.outputModule(1);
    outputModule.applyTemplate("Multi-Machine Sequence TIFF RGB");
    app.project.renderQueue.render();
    My problem is, I don’t know how to select the built-in ‘Render Settings’ template “Multi-Machine Sequence”. The closest I got was defining a few of the parameters using this snippet from Adobe…
    var my_renderSettings = {
    "Color Depth":"32 bits per channel",
    "Quality":"Best",
    "Effects":"All On",
    "Time Span Duration":"1.0",
    "Time Span Start":"2.0"
    app.project.renderQueue.item(2).setSettings( my_renderSettings );
    …but I don’t know how to add ‘skip existing frames’, and even so, it creates a ‘custom’ version of the default ‘Best Settings’, which I don’t want.
    Surely there’s a way to simply pick one of the ‘Render Settings’ templates with a script?
    Mark Paterson replied 6 years, 9 months ago 2 Members · 2 Replies
  • Walter Soyka
    November 13, 2019 at 2:31 pm
    [Mark Paterson] “Surely there’s a way to simply pick one of the ‘Render Settings’ templates with a script?”
    There is! You use the the applyTemplate method of the render queue item, like this:
    item.applyTemplate("Multi-Machine Settings");
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Mark Paterson
    November 13, 2019 at 6:19 pm
    That did it, thanks!
