Activity › Forums › Adobe After Effects › How do i use an adjustment layer for both eyes?
  • How do i use an adjustment layer for both eyes?
    Posted by Phil Campbell on July 31, 2020 at 5:58 pm
    Hey everyone,
    So I’ve been trying to edit my eye colour using video copilots colour vibrance plugin which says to add the effect to an adjustment layer.
    Whenever i do this it will only add the colour vibrance effect to one eye. I’m guessing there’s something really silly or obvious that I’m doing wrong.
    In the adjustment layer I’ve linked it to the right eye null but can’t parent it to the other one so even though I’ve masked both eyes inside the adjustment layer it still doesn’t work.
    Please help! ?
    John Cuevas replied 6 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Doyle Lewis
    July 31, 2020 at 6:55 pm
    That is a tough question. I am not sure exactly how that effect works on stacked masks. Have you tried copying those masks to a solid layer and taking them off your adjustment layer and then setting the adjustment layer to alpha matte the new solid layer? if the problem persists when you do that then there is some funny business going on that isn’t in the screenshot.
    Doyle Lewis,
    Assistant Location Manager
    Warner Brother Pictures
  • Doyle Lewis
    July 31, 2020 at 6:58 pm
    don’t forget to remove the parenting from the adjustment layer and add it to the solid layer when you try it
    Doyle Lewis,
  • Blaise Douros
    July 31, 2020 at 10:07 pm
    If it really came down to it, you could always just duplicate the adjustment layer, and use one instance for each eye. It looks like your tracking is already done, so it wouldn’t create any more work.
    I’m not sure why the masks are interacting that way with the VC Color Vibrance effect, but why fight it if you can solve it with a simple workaround?
  • Phil Campbell
    August 1, 2020 at 1:27 am
    yeah I tried that but it still only works on one eye at a time when I put them both into my main composition ?
  • Filip Vandueren
    August 2, 2020 at 10:07 am
    I don’t have the plugin, but it sounds like it lets you select a mask from within the plugin ?
    If so: Don’t select any mask
    Instead of that, add the masks in the compositing options of the effect in the timeline.
    That’s a relatively new feature that wasn’t available when the effect came out.
    This way also honours feathers, mask expansions, mask modes etc.
  • Blaise Douros
    August 3, 2020 at 5:50 pm
    On Adjustment Layer 1, delete the masks for the left eye, and on Adjustment Layer 2, delete the masks for the right eye. That way each Adjustment Layer is only looking at one mask.
  • John Cuevas
    August 3, 2020 at 6:10 pm
    Is your adjustment layer the full size of the composition? If it is, can you just upload your project file without asset here so we can take a quick look at it?
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
